When a blower in a vacuum application also has piping on the discharge side, resulting in positive pressure, how do you determine the flow, temp rise, input power etc from the performance curves? Most blower vendors' literature includes separate vacuum and pressure curves for flow, temp rise, and input power. Here's my actual example: the blower moves 420 scfm at 60" WC vacuum and 640 scfm at 8" WC pressure according to the charts. We have pressure indicators on either side but no flow indication. How do you estimate actual flow using the curves? Is the process the same for estimating input power, temperature rise etc. off of separate vacuum and pressure curves? Thanks for your help!
