reattaching an assembly cut sketch
Alfonz
Aerospace
May 20, 2014
31
I'm trying to understand assembly cut. I created one in my assembly by extruding a cylinder and cutting one of my components and it works fine. However, if I wanted to reattach that sketch to another face in the assembly, when I edit the sketch, none of the components are visible. I checked layers and reference sets and everything is visible. Am I missing something? I'm guessing it's something simple? I've attached a picture to show what's going on.
Thanks,
Al
Design Drafter
Alliant Techsystems
 http://files.engineering.com/getfile.aspx?folder=716a63b6-09d6-4580-a0db-1113fbf51752&file=Capture.JPG
What version of NX are you running? I just tested this in NX 9.0 and it seems to work fine, at least in the example I tried.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
John I am on 9.0.3.4. I'm getting this behavior and so are two other drafters with a different assembly.
Design Drafter
Alliant Techsystems
