Reattaching dangling dimensions 2
Trogdor0
23
Is it possible to reattach a dangling dimension in the drawing sheet with SW2004? For example: A block is dimensioned with an overall length and the end is cut off. Typically this would result in a dangling dimension within the drawing. We come across this quite often and have seen it done in 2005 but I can't find an option to do it in either 2005 or 2004.
Just drag & drop the dimension attachment point to the new location.
[cheers]
Eng-Tips.com Forum Policies faq731-376
Making the best use of this Forum. faq559-716
How to get answers to your SW questions. faq559-1091
Helpful SW websites every user should be aware of. faq559-520
When trying that all it does is move the length of the extension lines
Hmmm ... this is crazy (or I am) ... I did this less than 3 weeks ago on another machine, but cannot do it now on mine.
[cheers]
That's why i thought maybe there was a setting that i was missing but i can't find one. We just went through a 'Preventing/Repairing Rebuild Errors' class last night and they were moving the dangling dimensions in 2005. We thought maybe it was a 2005 option but we can't perform the task on our 2005 test machine.
I have not been able to do this since SW2003. I turned in at beginning of 04 release, but still nothing. Need everyone to turn it in.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP1.1 / PDMWorks 05
ctopher's home site
OK, I'm not going crazy (debateable). I was trying to re-attach a non sketch-related dimension. If your dimensions are manually placed on a drawing view, you are SOL! You cannot re-attach those. Delete & replace.
[cheers]
OK ... then I must be going crazy [bugeyed] ... I thought I had done this in a drawing just a while ago.
[cheers]
This is an issue with Reference/dimensions. It works with driving dimensions.
This is actually an issue with drawing sheets and not the acutal model or its dimensions. Therefore reference or driving dimensions don't make a difference.
For what it's worth, you can reattach ordinate dimensions.
Does anyone have any suggestions on how to reattach the dangling dimensions in the example that I posted?
What are you trying to reattach them to? The example you posted doesn't show any new feature!
[cheers]
Yes, delete them and re-dimension.
Try importing model items, per feature if necessary.
Otherwise, try to dim edges that do not change (bottom of your block instead of the top, etc.) if this is a standard type part.
Deleting and redimensioning can become a hassle. I know that other software packages allow this simple operation to be performed and I saw our VAR perform it last night. But I can't seem to replicate it in our office. Maybe a call to our VAR is in order.
CBL...In that example there isn't anything that would technically need to be redimensioned. In larger parts there is a possibility that there is a feature that needs dimensioned that is close by and a simple drag & drop would speed things up considerably.
