Hi All.
I'm looking for a mechanism that is reciprocal (driven by double acting air piston motor) that can also rotate the driven shaft 180degree from start of stroke to end of stroke and then rotate back to original position on the return stroke of the air motor.
I just cant wrap my head around the right search term to investigate what this mechanism is called and/or how others have done this.
Appreciate any keywords, etc I should be looking at.
Cheers and Merry X-Mas to you all.
