R Mohun
Chemical
- Sep 22, 2020
- 1
Hi Engineers
Appreciate your help. I have a hygienic single seat shut off valve with a double acting pneumatic actuator. The valve is normally closed but when it’s opened (energised) It takes about 3-4 seconds for it to open (open feedback). I want to make it open faster.
The valve has aN integrated ‘top’ with feedbacks and also two solenoids (one is normally open and the other normally closed which connects the air to top and bottom of the Valve actuator). When the valve is idle the NO solenoid feeds air to the top of the actuator which along with the spring pressure keeps the vAlve shut. When the valve is energised, the NC solenoid is opened feeding air to the bottom of the actuator opening the valve to overcome the spring pressure. I think the NO solenoid is closed at the same time.
