We are creating a manufacturing line in 3 D using items from all over(Screws, Clamps, Weld guns, the usual stuff) all in 3D. We have a layout(which is constantly changing) from a 3rd party that is 2D IGES from Cadkey. We would like to "Lay the 2D drawings on the floor" and use it as reference as we go along creating the 3D line. When we bring it into the assembly, it disappears. It appears to be on layer 61. If you select it from the tree and make it the work part you can see it fine. Layer 61 is selectable and we have tried visible only. If it is not the work part, we can't see it.
