Reference lines 3
TomMtz
147
Hi friends
I have a situation with NX11 sketch. When I use reference lines in a sketch and apply "finish sketch", I can´t visualize the reference lines in "modeling".
I use the reference lines in modeling mode like a "check point".
someone of you know how can I get it?
Tom
NX11 Windows 10
Take a look at the NX11 'whats new", I recall seeing that behavior, and the options for it referenced in there.
-Dave
NX 9, Teamcenter 10
In Customer Defaults: Sketch - General you have the option to display reference curves when sketch is inactive.
SS88
Thanks for your comments and solution. When I turn on this option, now I can see the references lines when sketch is inactive, but only with new sketches.
Old sketches did not change.
Tom
NX11 Windows 10
To change the old sketches first select "Sketch" to selection filter and then select them all by Ctrl+A. Then right-click on one of the sketches, go to Settings and enable the same option from there. I think this should affect the old ones as well.
SS88
Awesome! thanks a lot for your contribution.
Tom
NX11 Windows 10
