Regarding Spline curve 1
IEngr
68
Hi all,
In Catia, we have tension option for spline. Is there any similar option in NX8.5 ??
Can you add more information on what this tension option is/ does ?
Tomas
Hi
Tangent tension defines the tension value or weight that the tangent direction has. A higher tension value results in the spline being pulled more in the tangency direction.
Isha
Is this variable available when you do splines through points or Splines by poles ?
Is it available at each point or only the ones which have a tangency defined ?
In NX you can define the "tangent magnitude" by dragging an arrowhead or entering a value, IF you have defined a tangent direction.
Right click a spline point,- define constraint, then three handles will appear, One spherical handle which can be used to define the tangent direction, an opposed arrow for the tangency magnitude and a normal arrow for the curvature ( Radius).
Tomas
 http://files.engineering.com/getfile.aspx?folder=268e914e-f750-4556-a434-c554213acb17&file=tangent_magnitude.png
Is it possible to have asymmetric tangent magnitude in a point in NX? I see only symmetric option in NX 7.5 and I do not have access atm on higher versions.
Ivan:, Asymmetric tangents, not to my knowledge. I wonder how the curvature would look if we did this. (?)
Tomas
Tomas: it works in vector graphic software, and it gives fine solutions.
URL]
