Regular Height Nut vs. Reduced Height Nut
vbaldwin
5
Hi all!
I have a product which uses standard 316 nylock nuts. In one scenario, I need to use a reduced height 316 nylock nut for clearance. Is there a rule of thumb or quick calculation I can perform that will tell me what reduction in strength this causes?
The rule of thumb is that it takes about 3 full threads of engagement to produce nearly the full tensile strength of the fastener. Typically, because of deformation, the load is not carried evenly across all threads of a nut.
You may experience galling issues during tightening do to increased bearing load.
And then you need additional length for the locking.
Or look at a different locking mechanism.
vbaldwin Is the fastener loaded in tension or shear?
Mike
So, how is the nut loaded?
