Reinforcing Bar Lap Length Question
marinaman
195
I have a question regarding lap lengths of reinforcing bars.
If we have a concrete wall (say 10" thick), and we have #5 bars at 10" o.c., each face, horizontally for temperature and shrinkage reinforcing, what is the required lap length?
I've got shop drawings to check on such a wall.......
He's lapping the bars by 30 bar diameters......which would be 19"
But these are in tension......so if I followed ACI 318, a tension splice would be 40" in this instance.
But I don't need the full Fy.....its just temp and shrinkage reinforcing.
Can I accept the 19"? Could I accept the 19" if the laps are staggered from each other? Seems like there should be a provision for something like this.
I believe that temperature and shrinkage bars do, in fact, need to be developed and spliced for fy.
I think ACI would say you DO need the full fy for temperature and shrinkage control.
That being said, I wouldn't ask for longer lap lengths. I think a 30 bar diameter lap splice was traditionally used in the past, with no problems that I know of.
If the bars were acting as tension reinforcement in a structural member, I would ask for the full Class B lap splice.
DaveAtkins
I'd take another look at this as #5 @ 10" each face sounds pretty heavy for just temperature and shrinkage.
My Personal Open Source Structural Applications:
Open Source Structural GitHub Group:
I thought AASHTO and ACI were fairly similar for required laps and temperature & shrinkage reinforcement. Under AASHTO, for a 10" thick wall, S&T would be the minimum value of .11 sq. in. per ft, so #4 at 18" would be enough. The lap for a #5 Top Bar is either 29" (old ASD/LFD spec) or 31" (new LRFD spec).
Fy is definitely required, otherwise you have nothing to combat the cracking.
Maybe it's actually restrained. Those low quantities (<0.2%) are significantly weaker than the concrete so the stress that causes cracking mostly has to dissipate such as at contraction joints, rather than being picked up by the reo.
I agree that 30*diameter will probably do this job. Depends on concrete strength and cover etc though.
