BanditKeith
- Aug 9, 2012
- 11
Hi Everyone,
This is my first time sizing a pump in the real world and feel the need to refresh my mind on a few things.
I have been assigned the task of replacing one of our old sump pumps with a new pump. The original pump was a submersible pump that pumped the fluids out of the sump. The data books for this old pump indicated a suction head of zero due to it being submerged and a discharge head of 44 ft, so a total dynamic head of 44 ft. This new replacement pump is to be above ground with piping going into the sump to pump the water out of the sump. I have been told we want to keep the same discharge head of 144 ft.
I've calculated the suction head and the NPSHA to be around 23 ft and 21 ft respectively. I'm confident in my methods to calculate these values as I've seen them done before and did them in school numerous times.
What I can't seem to wrap my head around for some reason is what the new head I should size my pump for. My gut tells me that I need to size it for around 167 ft (23 ft suction + 144 ft discharge) since the pump needs to work harder to pump that water out since its not submerged anymore. Is this correct, or am I missing something?
Thanks, in advance, for the help.
