Relations to sketch entities in other sketches? 1
rokahn
48
Is it possible to make a relation to a sketch entity in another sketch?
For example, in part view, can I start an axis from the center of a circle if the circle doesn't have corresponding solid feature geometry. This might be the case if the circle is a construction line or if I haven't yet made it into a solid.
In your feature tree, open the feature to get to the sketch you want to relate to, right-click, and select 'show'.
Now you can relate entities(including centerpoints) in a new sketch to the existing sketch.
Remember...
"If you don't use your head,
your going to have to use your feet."
