I am a Mechanical Engineer and I am alittle lost here. This should be simple. We are try to hook up a automatic kill switch, so that when one piece of equipment goes down the other will shut down aswell. With the 1st machine we have a signal coming out that is .75V when it is on and 0V when it is off. The 2nd machine we have two terminals that when touched together will shut that machine off properly. I was thinking just hook up a relay to the .75V so when it goes off the relay connects the two terminals. Now I don't even know if that would work, but if it would, I am having a hard time finding a relay that would work? Is this possible? And if so where do I look for a relay? A coworker had mentioned something about a transistor, but from what I can remember, that wouldn't switch the power off?
Thankyou for the help,
Bigmil
Bigmil
