With two change-over relays I simulate a bipolar one. NO I CAN NOT USE DIRECTLY A BIPOLAR ONE. Why change-over? Because I want to use the normaly closed contacts to know if the relays are well off. My problem is that the NC contacts must have minimum 12V 100mA the ensure a good working (no oxydation, etc...) My problem is that the voltage is 230Vac; so with the 100mA that it needs it makes 23W! The other problem is that I don't have a lot of place to put some electronics. Just 3 x 1 cm !!!
My idea is to use a resistor in combination with a PTC so that when the relay is switched off the power dissipated into the resistor will cause heat so that the PTC thermistor will get the heat and then regulates the current flowing throught itself and the resistor. Another component placed near it (without any electrical contact) - a zener diode - will also get the heat and the current (generated by another circuit) flowwing through it will change. The change of the current can be detected and then I will know if both relays are off or not. Because if they are not there will be no current running through the resistor and its associated themistor thus no heat thus no changing of the current flowing through the zener.
BUT I don't know how to calculate the value of the resistor and which thermistor I have to choose. Can somebody help me? Already Thanks for reading this and the 'future' feeback. Best Regards. Yves
