We're working with a client on a field site automation project. They have about 90 sites where they will be monitoring a flow meter and control valve. Control will be by Modicon PLC. SCADA central terminal will use Wonderware Archestra software. Communications will be via cellular modem.
We're considering a field mounted data logger (in a NEMA 4 enclosure with the Modicon PLC) in order to store data during occasional communications outages. Proposed datalogger spec:
* Solid state memory (no spinning hard drives).
* Communicate via Modbus or Ethernet to PLC to monitor data registers.
* Capability to push data, or be polled, over SCADA/cellular to the central terminal (WW InSql).
* Small b/w or color graphic display for field monitoring of trends.
* User configured screen to monitor and control field devices (DP cells, valve solenoids) via the PLC.
We are particularly interested in the format of data and its transfer from the datalogger to the Wonderware Historian (InSql database). AKA the "InSQL solution". We are unsure if a CSV (comma separated value) file will be easy for WW to import and wonder if there's something better out there. Any ideas?
