rename the hybridshape instance in each geometrical set from 1 to so on
GajendraHG
Aerospace
Dec 26, 2023
5
Hi All,
i have fasteners details inside a nested geometrical set for the different diameter, here the instance its not in order like "en2245B3E4.3,en2245B3E4.8,en2245B3E4.12" i want to have vba code to rename the hybridshapes in the sequence, Please help me out
Gajendra HG
ok what is your progress? where is the problem?
Eric N.
I got the solution, Using "HybridShape.Name" i have extracted the name and renamed it.
Thank you for the response.
Good to know.
I had this renumbering problem once, this is what I did:
loop all elements (name xxx.yyyy) and rename than with "xxx.renumberyyy)
then loop again and rename them xxx.n , I got n from a dictionary that counted elements
Eric N.
@itsmyjob could you please response to my new query
