mrmalcolm
Marine/Ocean
- Jan 24, 2024
- 42
Is there any guideline for repair for stainless steel pitting, such as (1) if excavating pitting, what should be the ratio of diameter to depth of the excavation to ensure a smooth transition. (2) For deeper pitting, is it possible to use a non-metallic filler such as epoxy putty without excavation. (3) What is the pitting corrosion density of stainless steel, it is necessary to change the plate.
Thanks a lot.
Thanks a lot.
