XR250
- Jan 30, 2013
- 5,954
Got a massively termite damaged wall behind brick veneer. This is in a walk-out basement. The owner and contractor do not want to remove the brick. As such, my thoughts were as follows...
1) Remove the damaged stud wall and construct a new wall with pressure treated studs and 3/4" treated plywood sheathing.
Cover the plywood in ice and water shield and then add 1" thick vertical furring strips on top of that to act as spacers between the wall and the brick (there is currently no airspace)
The wall would be constructed on the ground and then stood up in place from the inside.
2) Fasten the brick to the wall from the inside by running Tapcons thru the plywood and furring strips and into the back of the brick.
Yea, I know this is not ideal from a water management perspective but seems to be a decent alternative to actually doing a full demo. I looked at Simpson Heli-Ties and I don't really see them working any better than this system and being a much bigger pain in the ass to install.
Thoughts?
Thanks!
Thoughts?
Thanks!
