Required Minimum Pressures for smart pig
hianbotech
Petroleum
Aug 23, 2004
45
Some one could help me in known required minimum pressures for running smart pig.
We are designing a natural gas gathering network that will operate between 58 psig and 109 psig. However we would like to know if it is possible run smart pig with this application. I know that this is information to be supplied by pig suppliers. But we are in conceptual engineering, and only I would like to know different experiences before I will contact the suppliers.
Many thanks in advance.
Hianbo
Mostly pressure doesn't matter much. What matters is differential pressure. With enough dP your can move a pretty heavy pig.
David Simpson, PE
MuleShoe Engineering
The harder I work, the luckier I seem
