REQUIRED WINTERIZATION FOR PUMP 3
virata
42
Hello guys,
I have a question, how do vendor winterize a pump? This pump is an AODD pump.
Thank you and hope to get some response from you.
Virata
I don't think any pump manufacturers do anything about winterizing their product. You could call your selected vendor and ask...
If you want to winterize it and leave it in a non-operating condition, there might be enough drain plugs that you can remove to get the liquid out and enough vent plugs to let some air in, so you can drain every chamber. ... which on an AODD could be quite a lot of work.
If you need the pump to be operable in winter, or you don't want to bother with a lot of plugging and unplugging, you could build an insulated box around the entire assembly, and put a suitable heater in the box. If the flow is high or the winters get cold where you are, you may need a pretty big heater. Also build in an appropriate louver so the exhaust air can get out of the box without too much snow getting in.
Mike Halloran
Pembroke Pines, FL, USA
Drain the pump. Clean out and flush any residuals. Blow hot air through the pump to dry out the pump interior.
Do you mean
1) how do you leave a pump in the winter not operating?
OR
2) how do you maintain opearability in "winter" conditions.
Either way what is "winter" (how low does it go?) and what are you pumping?
disconnect the suction and discharge and store the pump in the shop
Thank you guys for your reply,
LitteInch --- I meant the (2). Referring to P&ID this AODD will be installed outdoor ( i don;t know yet if location will change though). It will be installed in OHIO and it will be pumping condensate (mixture of water or hydrocarbon).
I don't understand why we have to drain the pump, is this related to pump operability in winter conditions? Please enlighten me.
Thanks,
Virata
People are misunderstanding what you are doing. Some think you are putting the pump away for the winter.
To winterize the pump, install self limiting heat tape and insulate. On alternative is a cellular glass insulation that will drain and not absorb hydrocarbons. Insulation will need to be jacketed for protection.
If you have steam available, you may heat trace with steam. The pump will have to compatible with steam temperatures.
An alternative to insulation is an insulation blanket. It should be fireproof.
Go to Walmart and buy some fluffy slippers,scarf, ear-muffs and a warm hat - should do the trick.
If this pump needs to be running intermittently outdoors in winter, another alternative to self regulating heat tracing / steam tracing is to ask the vendor if he has the option of fitting pump casing heater elements - these can be made to energise / de energise with casing temp feedback to a DCS TIC. This would avoid hot spots on the pump casing / uneven heating that may occur with other types of heating.
Thank you so much guys, I'll get back to you if I get some questions again.
V
