COEngineeer
- Sep 30, 2006
- 1,186
I work in Colorado. When you use steel beam (ie. W10X), what maximum or maybe comfortable to work with length do you usually specify? Sometimes I wonder if I should just continue the beam or stop it at a column and specify other smaller/bigger beam (with connection on top of the column).
