So, I am using Ansys fluent to run transient heat transfer analysis.
Then, I connect the "Results" component system to see the contours, work with the color legend, etc. BUT, I can only get the contours of the surfaces of the solid. The solids appear without the core.
As an example, I can only see the temperature isotherms in a cube face, and if I clip it, the interior is hollow.
Thank you in advance
