ksdphilippines
- Jun 20, 2002
- 36
Good day to all!
Our company ( a construction firm ) has been approached to check on a rusted reinforcements of slab, beam and rebars under the Comfort rooms of a school building.
The building is quite old ( around 30 years ). The beams and slab has already cracked mainly due to the expansion of reinforcements.
The problem may have started with the waterproofing of the CRs which were not done correctly or not placed at all.
Anyway, the second floor column has also rusted reinforcements which has been exposed already. The building is 6 storeys high.
Queries :
1.) What measures can be done for this problem?
( confined only to the CR area )
2.) We were looking into planting a new system of columns beams and slab for the area from ground floor. Are there other options?
your response will be greatly appreciated...
Bet regards.
Queries :
Bet regards.
