Im commissioning a central plant air handling system for a commercial building at present. One return air fan serves 3 air handling units. The fan is rated at 45 m3/s and each air handling unit is rated at 15m3/s approx. Its a VAV system so the AHU fans ramp up and down on a VSD to maintain a constant supply air pressure. How can I control the speed of the return air fan?. We have no air flow stations on the return air system. I was thinking of using the return air attenuator for which we can plot a system curve and depending of pressure drop equate the air flow rate. This would be done via the BMS of course. Some people say put a pressure sensor in the return air shaft, and maintain a constant pressure here. I have my reservations about this one. Any ideas?
