Do you think trying to re-use 1964 air handling unit refrigerant coil with new refrigerant is a non-starter because:
1. New refrigerant pressure?
2. other reasons?
Assume there is no information on the existing coil available - which would be actual case.(other than size and connected condensing unit tons)
I would assume that it can't and shouldn't be reused but want explore all possibilities.
2. other reasons?
