Need to get your input on going from multi ratio revenue meter to single ratio.
Only the CT discrepancies are listed:
The existing one:
200/400:5 DR with 1.5/2.0 RF
Thermal rating: 3000 VA
Proposed one:
200:5 SR at 4.0
Thermal rating: 4000 VA
The VT ratio (700/1200:1:1), accuracy (0.3W,X,M,Y,X,ZZ), nominal system voltage (138kV), BIL=650 kV are all same.
Would the proposed meter work? Since RF is higher, the max primary current will be same as the existing one.
Let me know if further info is needed.
The existing one:
Proposed one:
200:5 SR at 4.0
