Swedishrigpig
Marine/Ocean
- Sep 22, 2009
- 49
Gents
Our Ocean going vessel uses Reverse Osmosis to make drinking water out of Sea Water. Great machine, much less maintenance than the old Evaporator Distillers. However, although the water is very clean, it gets very aggressive and corrodes Steel Pipes, Aluminium coolers, Coffee machines, taps, valve seats, Expensive Variable Frequency Drives (fresh water cooled) even in systems like engine cooling water with corrosion inhibitor mixed into it, it eats up a aluminium radiator in a few months.
I have done some research, and it seems to be due to "lack of minerals or Ions" it will absorb that from wherever it can get it, pipes coolers etc.
The pH is 7.5.
Very low salts or chlorides.
1. How do I stop it?
2. Do I need to replace our entire Carbon Steel pipe system with Stainless Steel or Plastic?
3. Can a mineralizer make it "neutral" or mild again?
4. Can I save our Carbon Steel pipe work, even though it is corroded inside?
5. The water that comes out is always yellow/ brownish and looks terrible.
RP
The pH is 7.5.
RP
