1
- #1
jassco
- Feb 22, 2011
- 547
Hi, Guys:
I have a question about revision of assembly (or sub-assembly) drawing documents. Since this is a drafting standard forum, I assume my question below is an appropriate one.
When you make a minor revision to a component, do you revise drawings of all sub-assemblies and assemblies where this component is used? I am familiar with ASME Y14.35M - 1997. But that is a legacy standard before 3D modelling. I do know there is a new standard ASME Y14.35-2014 released in August 29, 2014. I do not have a copy and I am wondering if the new standard says anything about assembly revisions.
Say, for example, you have a simple part. You add a hole to it or add some marking which does not affect form, fit, and function. So, you revise this component through revision. But what about all assembly and sub-assembly drawings? Do you revise them too as views of models on those assembly drawings are changed? We also use derived parts. So, this nesting can go very deep.
What's your thought on revision of assembly drawings?
Best regards,
Alex
Best regards,
Alex
