RichardMid
- Mar 30, 2003
- 17
Hi all
I am modulating a signal up to 433MHz. I am forced to use through hole components like regulators and variable resistors, and then of course the surface mount high frequency components. I would like to know if it will cause trouble if I use the RF and IF components on the same PCB. Should I try to seperate the low and high frequency components on the same PCB?
As I am unexperienced with RF and RF circuit board design I would like to ask a few more general questions. Is it necessary to use use decoupling caps on every connection to ground and Vcc. Should I try to ground the pins that need to be grounded as close as possible to the pins or doesn't it matter. Where can I find text on RF circuit board design e.g. hints and tips or rules of thumb.
Richard
Richard
