Emiliano87
- Oct 4, 2013
- 11
Hi, I am trying to make a simple exercise of using two rigid bodies(tools) to make a plastic deformation in some kind of part. It would be a fixed rigid die and a rigid tool that pushes the steel piece to the die. I searched everywhere on how to make a body rigid in advanced simulation and I didn´t succeed. One what I found to work around this issue is to fix all degrees of freedom in the fixed die to make it rigid. But with the tool that is moving is not that simple. Am I missing something? is there a way to make some rigid body without setting a reaaaally high Elastic modulous??. Thanks for everything
