Rigid Concrete Column-Beam Frame
otto_eng
88
Hi ,
I am designing a concrete beam- column rigid frame for a 5 story timber building to resist the wind load. I am not planning on having pinned connections at the foundation level so in a sense only the top & bottom of the concrete columns and beams are taking the moment. Is linear analysis sufficient for this type of a condition or would you guys also do a nonlinear check as well ?
Thanks in advance !
 https://files.engineering.com/getfile.aspx?folder=7689aff0-c93a-4273-abea-6e34307583d6&file=Concrete_Frame.jpg
You will want to account for p-delta effects somehow.
