Jackfeng
Petroleum
- Nov 28, 2002
- 7
An equipment made of carbon steel will be used about 30 meters under seawater. The wetted surfaces are coated and cathodically protected.
Bolts are used to connect a cap into the body. The bolts heads are exposed to seawater. One concern is that the seawater can get into bolt hole through the mating surfaces and may cause corrosion to the bolt hole and scew.
Anyone can tell me if this risk is high and how to provent it? Thanks a lot.
