curiousmechanical
Hello Everyone.
I have a beam bending problem that I am currently working on (please see the attached .pdf).
I am looking for the max deflection of the beam.
A colleague gave me the direct formula from Constrado, “STEEL DESIGNERS’ MANUAL,” Fourth Edition, pg. 43.
However, I am a Roark’s fan and I would like to know how to solve the problem using Roark’s bending tables. Roark’s doesn’t give the direct formula, but I can’t help but think that you can solve this using superposition or some other neat manipulation.
You can see my attempt on the attached .pdf, but it doesn’t work out (I came out too low). I checked the solution using FEA and confirmed the direct formula result.
Does anyone know how to manipulate Roark’s formulas to get the correct result?
I am going nuts trying to figure it out.
Thank you!
Thank you!
