Could you share experiences or recommendations that are important to take into account when selecting a robot that meets with the following application:
The robot should be able to travel in XYZ axes through switches on a panel with an area of 10 "x 10" x 8.5". Once the robot is positioned on a key must be able to take measurements of pressure and force and distance required to activate the key. Worth mentioning that there are different types of keys such as button, slide and open/close Lid.
also can your recommend any brand?
Thanks in advance.
Thanks in advance.
