moe333
Geotechnical
- Jul 31, 2003
- 416
Hello all,
I am putting together a laboratory testing program for a FERC regulated rock fill, clay core dam, about 100 feet high, and have not been able to find complete criteria on their requirements. I do have their September 2006 manual "Chapter IV", embankment dams, but it is not comprehensive. I also have the 2007 USSD paper "Strength of Materials for Embankment Dams" which gives criteria for different agencies.
dgillette, I thought you may have some insight on this in particular:
To develop a composite shear strength envelope with the R-bar, and S tests for either steady seepage or earthquake loading, would it be permissible to use the direct shear test for the S test? I'm trying to avoid using the drained triaxial test on clay material if possible.
Also, does anyone know what the compaction requirements are for clay core and filter material? Is it standard or modified proctor? Is this referenced somewhere by FERC?
Thanks for your replies.
