moe333
Geotechnical
- Jul 31, 2003
- 416
I am using filter criteria by Sherard and Dunnigan to design a filter for a clayey silt (52% fines) core in a Rockfill dam. The filter according to this criteria would have a D15 less than 0.7 mm, and less than 5% passing the #200 sieve. A typical concrete sand would fit this criteria. I assume the less than 5% passing the #200 sieve criteria is to reduce head within the core.
I would be concerned about water pooling in the filter since the zone downstream of the filter will be a silty sand and gravel (decomposed granite) which may have about 20% fines, and will be significantly less permeable than the concrete sand. I could include a blanket drain to tie the filter into the outer rock fill shell, but I wanted to avoid the use of a blanket drain if possible.
There will be several material zones downstream of the core filter. Each zone will be progressively more permeable, and coarse, until they reach the downstream rockfill shell (2 foot minus material). The way I interpret the Sherard and Dunnigan criteria, each of the downstream zone materials would need to have less than 5% passing the #200 sieve. This doesn't really make sense to me.
Any comments or suggestions regarding the 5% passing the #200 sieve criteria, or transition/filter criteria for the progressively more permeable downstream material zones.
