neoncookies
- Sep 21, 2018
- 2
Hello - This seems very basic and I may just be overthinking it, but can someone help me with the following:
Does the diaphragm resistance needed on a roof change depending on the wall construction? For example, is the diaphragm requirement different if the walls were concrete tilt-up versus steel framed walls (e.g. conventional or pre engineered)? Or is it just a matter of load transfer assuming the walls are properly designed?
Thank you in advance.
