lubos1984
- Jul 5, 2019
- 65
I'm looking to create a loft in an attic that has a roof constructed from trusses. I've attached a sketch to show what I'm trying to do. Essentially I would like to remove the 3 chords in the hatched out section.
I'm wondering how would i go analyzing and strengthening the existing chords like the ceiling and top beam ? There are no load bearing walls underneath. For the ceiling, should i analyze it as a regular floor load since those 3 chords are removed? If i need to add floor joists can i span them just to the edges of the opening and tie them in to the existing trusses.
happy to hear your thoughts.
Thank You!
Thank You!
