Rotary to Reciprocal motion 5
heidt
4
Does anyone know a mechanical way to convert rotary motion to reciprocal motion withen a confined space?
Ok, I'm not sure whether my suggestion has a name for it or whether it's mentioned. My suggestion is to use a long threaded rod with the pitch travel you wanted per revolution. Add a coupling at one end so that a motor can be attached directly or through a step down. Next, put a piece of metal with a threaded hole that mates with the rod. Restrict the rotation movement of the metal piece but not linearly.
How about a Geneva machanism? they are simple to make and will do the job. I recently saw one on an automatic pancake making machine. It was great!
