designmechanical111
- Apr 5, 2008
- 7
I am trying to rotate 60" long shaft of dia 4" made of SST 630 need to rotate at 60 rpm. If the shaft is resting on a bearing at both the ends, which formula do I use to calculate the power required to rotate this shaft considering self load of shaft and overcome the friction of bearing.
