ab110
- Feb 27, 2011
- 55
Dear All,
I have posted a question about rotation of a local coordinate system but I did not get any reply. Today I thought to make the problem clearer and post it again. Hope this time I can get some replies.
In the attached picture I want to make the rigid cylinder rotate about the Z axis of the local coordinate which is at the center of the cylinder. How can I make the cylinder rotate with a constant speed about the local X-axis which changes its direction due to rotation about Z-axis? The rotation of cylinder is similar to the rotation of the wheel in an automobile (rotation about Z axis due to steering while the wheel always rotates about X-axis that changes its direction).
I have tried to find the solution using connector elements. I think this should be the right way but unfortunately I have not been able to get the required rotation (the file is attached). The cylinder always rotates about the global X axis with constant direction and I cannot define for the software to change the direction of X-axis due to rotation of coordinate about Z-axis!
I appreciate if someone pleas help me fix this issue.
C,
A
C,
A
