srimanishreddy
Automotive
- Mar 12, 2018
- 13
Hello Guys,
I am presently working on Abaqus to analyze contact and pressure on a revolute joint(hollow cylinder-bushing over a solid cylinder-pin) when it is subjected to dynamic loads.
1.The pin is attached to the pin plate with a surface-surface explicit hard contact interaction and so is the sleeve to the sleeve plate.
2.The sleeve slides on the pin with a tangential-penality explicit interaction.
step1: To pull the pin plate with 20N force to achieve the pretention in the joint. To do this, I have fixed the sleeve plate edge and applied the pressure BC to the pin plate with the option 'total force'
step2: The pin plate is rotated with the pretention still on to analyze the contact pressure on sleeve during the motion along with loads
problem: I am able to achieve step1 but when the next step starts solving, Abaqus exits with an error. But I am quite sure the problem is with the rotation(BC's or others which I am seeking help for) as the model starts to rotate in a weird manner.
I am attaching the python script for reference to understand the boundary conditions which I gave.
