Routing Table Updates
polykracker
19
Is anyone else having trouble having the routing tables update with the correct cable/wire lengths? I fixed the length of cable to 10" made a drawing and decide to re-fix the length at 12" but the tables won't update to show the 12" cable length. It the correct length will show up if I create a new drawing. Am I missing a setting somewhere? I am running SW 2008 SP2.0
Haven't used routing in a while, but what you describe sounds like an SPR we saw in 2007 (maybe it is back).
What happens if you delete the table and recreate it?
If I recreate the tables they still show the old lengths. This also happpens to the lenghts generated using the flatten route feature. Our VAR is looking into this and hopefully they come up with a solution.
