Rule Of Thumb For Fillet Weld Size
Veer007
379
Hey guys
This may sound silly,
If forces are unknown, is this a good practice to determine fillet weld size by the below table? Also, fillet leg and fillet size are the same?
Thanks in advance!!
desertfox said:
So the a plate is welded central in the HSS tube And then using bolts that plate is fastened to the gusset plate is that right ? Also how is the HSS section loaded when in position?
Right and This HSS going to support a CMU wall over the opening.
Thanks in advance!!
