resilientsoma
- Jul 11, 2012
- 34
Is there a site where I can learn more about pipe diagrams?
Currently we use a mechanical setup to isolate hydraulics in 2 areas by turning a handle attached to a sprocket and chain, rotating the shaft to the other side where the valve is located - which is not accessible. The setup is not ideal, so would like to add another valve in series where it can be easily accessed. This isolation is an Interlock, not LOTO.
The mechanical setup consists of a handle (acts as gate one this side for no entry) that can be turned attached to a chain and sprocket that turns a shaft. The other side of the shaft is where the valves are in place. This side of the shaft is also attached with a chain and sprocket, turning the valve attached to a handle (acts as a gate on other side) to be isolated so there is no energy to the trough. The trough is the danger, which moves and can hurt someone severely. This is what the isolation is needed for.
The setup consists of turning a handle that turns two valves, one for drainage, and isolation, 2 valves acting as a 3-way valve. I would like to put another valve I'm not sure how to run this in series. The valves would be turned in series, and would drain in parallel (I assume).
Also, I'm not sure if there are OSHA requirements for this, since we are in the grandfather clause. What are the current redundancy requirements and for dual channels?
Your help is greatly appreciated!
