Safety valves vs Shut down Safety Systems 8
brainstorming
Chemical
I would like to hear from you about unclear matter to me regarding eliminating PSVs in compressors discharge piping by providing high integrity safety shutdown system.
An example of that PSVs installed in the compressor discharge protecting the compressor from blocked discharge case, the question here:
Can these PSVs be eliminated when high integrity shutdown system is provided (i.e. PT 2 out of 3 voting)?
Does the code allow for that ?
Thank you
Guidoo,
I agree with everything you write but I have one question concerning the reliability data of safety valves.
I know that some companies use a PFD (probability of failure on demand) factor of 0.01 (which comes up to a failure of 1 per 100 demands compared to 1 per 1000 demands in your message) for PSVs.
This would result in a different SIL classification for the described safety instrumented function. Are there any reliability data for PSVs public available (besides OREDA)?
Sorry, this is not exactly matching to this thread but I thought it would be a good opportunity to ask...
Thanks a lot and Best Regards
The CCPS (Center of Chemical Process Safety) database shows for spring loaded safety relief valve, failure mode "Fails to Open on Demand" a mean value of 0.212 failures per 1000 demands. This falls in the SIL3 range.
For Pilot Operated Safety Relief Valves they give a mean value of 4.15 failures per 1000 demands. This falls in the SIL2 range.
From my previous experience I always used three PSHH (dublicated) at cenrifugal compressor's discharge line.
Code for this - B31.8 par. 843.441
For reciprocating compressors PSV should be used.
API 14C (1998), API 521 (1997), and Code Case 2211 (1995) of ASME Section VIII, Division 1 and 2, provide alternatives in the design of overpressure protection systems. These alternatives revolve around the use of an instrumented system that achieves a level of safety that meets or exceeds the protection provided by a pressure relief valve and flare system.
Any instrumented system used to provide over-pressure protection is a safety-related system, since its failure would result in the rupture of the pipeline/vessel or in overloading the flare. As a safety-related system, the instrumented system must meet either the United States domestic ANSI/ISA S84.01-1996 (1996) or the international standard Draft IEC 61508 (1998, 1999). Due to the high likelihood that the instrumented system would be needed and the high severity of the consequence should these fail, the SIL assigned per the standards is often 3 (or simply as high as achievable with redundant architecture, high availability devices, and frequent proof testing). Due to the high availability requirements, these over-pressure protection systems are often called “high integrity protection systems” or HIPS.
Industry is increasingly moving towards utilizing HIPS to reduce flare loading. They are becoming the option of choice to help alleviate the need to replace major portions of the flare systems in existing facilities when adding new equipment or units. The relatively low capital cost of HIPS compared to flare system piping upgrades and the ability to install HIPS without incurring significant additional downtime during a turnaround, makes these systems an extremely attractive option.
However, prior to making the choice to install the HIPS, the regulatory and industrial standards pertaining to their design must be well understood. Due to the unique nature of the HIPS application, certain design aspects must be carefully evaluated. Any company considering HIPS is cautioned to do a thorough hazard evaluation prior to the implementation of HIPS.
HIPS do not differ greatly from other trip systems. The systems are composed of field-input devices, a logic solver and final elements. The necessity for high availability and reliability is where the differences truly begin. Redundancy in field devices is utilized to provide a high level of availability while, at the same time, increasing reliability. Typically, the inputs are configured in a two-out-of-three voting basis, the logic solver should have high availability, and the final elements are configured one-out-of-two. The design of any HIPS should be quantitatively verified to ensure it meets the required availability.
Care must be taken in any decision to implement HIPS. The use of HIPS should be generally restricted to the reduction of relief and flare loading in existing facilities. The use of HIPS should not be a justification for reducing the pressure relieving requirements on individual pieces of equipment. The pressure relieving of vessels should be sized for the worst credible scenario for each piece or groups of equipment irrespective of the HIPS design.
Advantages of HIPS:
• Low capital costs compared to upgrading flare systems
• Can be installed without incurring additional downtime during a turnaround
Disadvantages of HIPS:
• HIPS require that many different components work as designed.
• Effectiveness of system is highly dependent on the field design, device testing, and maintenance program.
• Limit of knowledge in the identification of all over-pressure scenarios
• HIPS becomes the “last line of defense”. Failure results in potentially over-stressing of vessel.
Hi brainstorming,
After giving due consideration to all of the above, pl consider this:
If it is a positive displacement compressor, provide PSV and if it is centrifugal, axial, etc, go for HIPPS. This agrees with JETEE, I suppose.
My two bits.
HIPPS is a substitute for those cases when the risk cannot be practically reduced to a tolerable level. The Safety Integrity Level is assigned based on a risk assessment of the identified hazards.
As mentioned earlier, some countries place heavy restrictions on flaring so in these cases, the environmental and/or financial risk assessments may over-ride the safety assessment. There is no hard and fast rules on when to use PSVs vs. HIPPS. Each situation needs to be addressed individually because individual corporate risk tolerances vary. In existing facilities where the flare size is fixed, HIPPS would be a method to reduce the risk where to increase the size of the flare system would be cost prohibitive.
The best method we have today for designing and maintaining safety systems is IEC 61508/61511. These standards outline a good practical methods.
sdl
