save animation but image size often changes
robertt3
21
I use the following settings to save animation from ODB results. However, the image size often changes. For example, the size was 4096*2252 in my last saving, but it goes 4096*2273 this time. It seems that the size setting is randomly changing. And the terrible thing is that I can not change it as the x and y change proportionally.
Which version of Abaqus is it ? Did you try with different formats ? Maybe recording your screen with Abaqus animation playing would be better.
Hi FEA way! It is ABAQUS2020. I think it is not the problem with format. The size setting should not change randomly no matter which format is chosen. In fact, I always record my screen with Abaqus animation playing. So, I guess that there must be something else to affect the image size setting.
