save font settings for note
jonnythefox
Industrial
Aug 21, 2014
8
NX 8.5.3.3
If I create a note in drafting , go to the settings of the text , change the font type, color etc and then save that as a favorite. when I reapply the same text using the favorite tab the text has lost all the settings and reverts to system defaults.
Is there something I am doing wrong? Is there an alternative way to this?
Basically I want to save text to a certain size and color and quickly apply it as a note in various drafting files.
hi,
1.First create the Save Favourite using
Dialog Options > select Save Favorite As .
Now your saved 'Save Favorite As' dialog box is displayed.
2.Now You can do the changes of your 'Note' and again save it as Favourite.
Thanks,
Mathi K
Hi Mathi ,
Thanks for the reply ,
That was the way i was trying to do it but it just seems to retain the text as a favorite and not the settings.
Why not create a group for your note?
Uploaded is a video to show how you do that.
You can then copy & paste the group (past with a Control V) into other loaded parts.
Personally I would create your a group for each of your preferred font setting in your drawing templates.
Then when you create a new drawing using your drawing template, you can just turn on the notes you want when required.
Anthony Galante
Senior Support Engineer
NX3 to NX10 with almost every MR (21versions)
Thanks for the video,
It would be a good idea to create groups and turn them on as suggested,
I am using a macro for the note as a workaround at the moment. It works fine but I will look into using the note as a group in a template.
Thanks again for taking the time to do the video.
