  • Congratulations Danlap on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
saved section 2
snewton
5
How do I save a sketch in Pro\E then reuse it in another sketch?
Try the ProE forum for better response.
Hi Snewton,
In the section you wish to save, click File, save, use default name and remember it. Then go to the new part and set up the new section you wish to create (copy to) and click sketch, data from file, chose file type .sec and you should see the section you just saved and pick it.
You will have to play around with this to get the hang of it.
Tofflemire
Thanks, Tofflemire! That worked perfectly! I appreciate it.
