asimpson
- Aug 6, 2010
- 300
I wish to seal surface of aqueous solution at the liquid surface to prevent evaporation. Solution contains acetic acid. This is a small stainless steel beaker about 10 mm that is half filled with solution. Cant seal with solid object like rubber cap
Can anyone recommend a resin or wax that could be floated on surface that will bond with walls of stainless steel can.
